1993 F150 Ignition Switch Replacement
Old Jun 28, 2010 | 04:33 PM
outdoornut42's Avatar
Default 1993 F150 Ignition Switch Replacement
How hard is it to replace switch and does steering wheel have to be removed to replace turn signal/wiper delay switch? Thanks!
Old Jun 28, 2010 | 07:15 PM
way2old's Avatar
It is easily replaced. The steering wheel does not have to come off. If it has tilt, remove the tilt lever. Then remove 3 screws under the lower steering column cover. Threr are 2 little torx headed screws that hold the switch in place. Remove the screws, unplug wiring and replace switch.
Old Jun 29, 2010 | 01:51 PM
Is the ignition switch easy to replace, I've been told just to move switch to run position and use small drill bit in hole under ignition switch (shroud) to release pin that holds in ignition switch and switch pops out?
Old Jun 29, 2010 | 07:32 PM
way2old's Avatar
If you are talking about the key cylinder, you have the correct procedure.
Old Jun 30, 2010 | 04:09 PM
Thank you for your help!
RickE33
Mar 2, 2014 04:55 PM
pappapat
Nov 13, 2013 02:37 PM
luigi87
Sep 10, 2013 11:40 PM
BustedVan
Aug 2, 2013 05:33 PM
Downhill Stan
Dec 30, 2009 06:34 AM
