blower motor woes
Old Jun 30, 2010 | 08:45 PM
dlensing's Avatar
Default blower motor woes
I have a 2007 taurus and the blower motor only works in high. I figure it is the switch. Can y ou replace just the switch or do I h ave to replace the whole temp control panel?
Old Jul 8, 2010 | 04:36 PM
way2old's Avatar
If it is just working on high, the blower resistor is probably the problem. When they burn out, they default to the high blower setting.
Old Jul 9, 2010 | 08:19 AM
dlensing's Avatar
Default location?
Where is the resistor and what does it look like. thanks
Old Jul 10, 2010 | 07:22 PM
way2old's Avatar
Removal and Installation
Remove the RH lower instrument panel insulator.
(thumbnail1)
Remove the blower motor resistor.
Disconnect the electrical connector.
Remove the 2 screws.
(thumbnail2)
To install, reverse the removal procedure.
Attached Thumbnails blower motor woes-tarus1.jpg   blower motor woes-taurus2.jpg
Old Jul 14, 2010 | 09:15 PM
dlensing's Avatar
Smile thanks
Just put a new resistor in. 20 bucks at Oreillys. Worked like a champ. I love this internet thing. Much appreciation.
Old Jul 15, 2010 | 07:03 PM
way2old's Avatar
Thanks for the fix post. And thanks for using our forum.
Old Aug 16, 2010 | 10:27 PM
dlensing's Avatar
Default happening again
It has been over amonth and my sons girlfriend just told me that it is not working again. Cougd it be the resistor again? Maybe should have gotten oem instead of orielly. Any thoughts?
Old Nov 10, 2010 | 07:26 AM
cutiepiereading's Avatar
Smile 99 taurus blower motor
Thanks for the heads up Way to old, i'm having the same issue and you confirmed my suspicion. You, as always, have been a great help. Have you had any issues with the blower motor resistors from the parts discount stores or do you always use OEM in your shop.
Old Nov 10, 2010 | 06:59 PM
way2old's Avatar
If it is doing the same thing (only working on high) it is possible the resistor has burned out again. If it does not work at all, first look at the fuses and then the switch. Check the connection also to be sure there are not any burned wires inside the connector.
cutiepiereading, we use Motorcraft parts obtained from an aftermarket supplier. We have not had any problems with any of those. of course Motorcraft is Ford's aftermarket part.
Old Nov 13, 2010 | 10:03 PM
Default problem fixed
Thanks for the heads up, the new resistor has fixed the problem.
sannis
Dec 22, 2007 11:25 AM
raggy742000
Oct 23, 2007 08:59 AM
mattymax
Mar 2, 2006 12:46 AM
KSA
Nov 11, 2005 02:08 AM
savvy5473
Sep 7, 2005 02:31 AM
