1995 4.6 Ford thunderbird V8
Old Jul 11, 2010 | 12:42 PM
patrick McGuinness's Avatar
Default 1995 4.6 Ford thunderbird V8
Scanner say's EGR valve Eclusively. Help
Old Jul 11, 2010 | 12:43 PM
How do I replace egr valve 1995 4.6 V8. Thank's
Old Jul 29, 2010 | 02:19 AM
It is located on the intake and uses a tube from the exhaust which connects to it. (Exhaust Gas Recirculation - EGR) Unbolt it and the tube most likely.
Old Jul 29, 2010 | 03:09 AM
Many times the EGR valve is OK. but the sensor above it is defective. Be sure , before you go through a lot of unecessary trouble and expense.,,,,hanky
Old Jan 14, 2011 | 07:29 PM
Birdfan's Avatar
Trying to find an Instrument panel finish panel for my 1995 T bird.Have checked with Ford,junk yards,and online.Have only found this part for newer models. It's the plastic trim housing that goes around the instrument cluster.Mine was broken,& damaged while having the A/C evap,and heater core replaced .
Old Feb 1, 2011 | 07:48 PM
bulbird's Avatar
Default 97 bird cam shaft sensor
My 97 4.6 bird is showing a code that the reader says is a camshaft position sensor. Where is this sensor, and what do I do about it. Thanks all.
Old Feb 5, 2011 | 06:08 PM
Schneider153's Avatar
The cam sensor is located on the driver side of the engine. It is in the front cover just below the valve cover.
Old Feb 6, 2011 | 03:47 PM
bulbird's Avatar
Thanks. I will see if i can find and replace it now.
Old May 4, 2015 | 02:45 PM
azoutlaw359's Avatar
does anyone know how to set the timing on a 1995 ford thunderbird 4.6L have found many many post on other sites about checking the timing but nothing on how to set it! am thankful for any help
thund3rchick3n
May 30, 2011 05:42 PM
danny88
Jan 31, 2011 12:26 PM
danny88
Jan 31, 2011 12:25 PM
danny88
Jan 31, 2011 12:24 PM
dominantmind
Nov 13, 2007 01:07 AM
