rear ac low air flow
Old Jul 11, 2010 | 03:09 PM
grtrans's Avatar
Default rear ac low air flow
. low air flow from rear ac duck system control damper working correctly replaced blower motor an squriel gage , replaced resister ,contacts condenser looks clean . does not seem to be able to trasfer enough air across condenser removed fan motor straiht to good battery has great air flow . removed hard plastic duck air comming throuht opening . have nine 3-350 vans ,removed duck from other checked the same way much better air flow . removed all the parts listed above from good van installed on this prlbem did not change at all. could condenser be restricting airflow please help
Old Jul 11, 2010 | 04:26 PM
In reply to your question, sure it (I believe it's called evaporator) could be restricting air flow ,but I noticed no mention of the fresh air door. Does the air flow change when on MAX ,which is recirculating interior air ? Wondering if you have an air blockage other than through the evaporator.
Old Jul 13, 2010 | 03:07 PM
We forgot a very important check. The wiring and contacts for the blower motor at the switch itself could have become overheated and when cooled down now have poor connections. Have seen this problem in other ford trucks. Remove the blower motor switch and check the connections which I believe are in plug form. If the black plastic has melted you found the source of your problem. Let me know what you find. Thanks,,,,hanky
Old Jul 25, 2010 | 09:40 PM
xing's Avatar
Default who know http://www.eluxuryblog.com
is there any one know if http://www.eluxuryblog.com selling the authentic bags ? I have bought from them ,but the price is cheap that I doult
angelique659
Feb 24, 2010 03:02 AM
irrigonres
Mar 31, 2009 02:39 PM
ronaldcarson
Apr 4, 2008 06:11 PM
dzags18
Feb 28, 2008 09:25 PM
SSHUNTR
Jul 3, 2006 05:49 PM
