2000 Expedition Trans Question
Old Jul 15, 2010 | 02:11 PM
heatershog's Avatar
Default 2000 Expedition Trans Question
I have a 2000 Expedition, Codes are as follows: P0743, P0755, P1747, P0443, P1451, P0135, P0155, P1409, P0141, P0161.
When put in gear motor starts to miss very bad. When put in 1st truck will move but still misses very bad
163,000 miles
Any help would be apprecitive.
Wayne
Old Jul 15, 2010 | 07:27 PM
In trying to decipher those codes, many relate to the oxygen sensor heater circuit. Check all the fuses first. From what I was able to conclude most if not all your codes are from an electrical failure supplying several systems.
For now I would start with all the fuses and replace any that are bad and see what you uncover. hanky
Old Jul 18, 2010 | 09:31 AM
heatershog's Avatar
Default Fuse
I found fuse number 23 under the food blown, I replaced the fuse and everything seems normal. The fuse description is HEGO Sensors,Canister Vent, Automatic Transmission, CMS Sensor
Any Idea what may have blown the fuse?
Old Jul 18, 2010 | 05:54 PM
If it doesn't reoccurr, I wouldn't worry about it. If it does blow the fuse again, there apparently is an intermittent problem. It could involve any of the circuits the fuse protects. Lets see what happens before we get overly concerned OK. ,,,,,,,,,,, hanky
Old Jul 18, 2010 | 07:55 PM
heatershog's Avatar
Default Thanks
Thanks hanky, The truck is new to me, the only thing I have a concern with is the shift from first to second is abroupt if I'm on the gas. If I baby the gas its fine. Could this be the problem? would this be the first shift module is this hard to change?
Thanks again
Wayne
Old Jul 18, 2010 | 09:06 PM
At this point I don't think so. Trying to do this right we need to do some more checking. Sometimes, when you have corrected a problem the computers need time to adjust to a new shift schedule. Drive the vehicle normally for a while and see if the problem lessens or goes away completely OK? Patience pays. ,,,,,,,hanky
Old Sep 1, 2010 | 02:29 PM
ICEFRZRCOOLER's Avatar
I
163,000 miles
Wayne
I have the same problem with my 02. Did you find the problem?
Janelle
Old Sep 2, 2010 | 06:36 PM
heatershog's Avatar
Janelle
Fuse number 23 under the hood
Good luck!
conanalois
Aug 31, 2013 06:16 AM
joemar6988
Mar 29, 2008 10:32 PM
anjm2004
Jul 28, 2007 03:34 PM
Hockey Stud
May 3, 2007 09:49 PM
Sanguinius
Dec 22, 2005 04:49 AM
