Alternator slowly not charging
Old Jul 25, 2010 | 07:17 PM
awwphooey's Avatar
Default Alternator slowly not charging
Hello folks-
Any help on this would sure be appreciated. I have a 1996 4 cyl Ranger. Issue is, I was driving to work and the ammeter indicator started wiggling around. It started dropping, and when I revved the engine, it would pop back up- but eventually, even that wouldn’t work and it died. I was stuck without my tools, so I got a ride to the local Walmart and dropped a new battery in. Made it home, but the same thing happened as I pulled into my driveway.
Charged the battery, got out the voltmeter, battery is at 12.4 V when not running, started the engine and started at 14V, then slowly over 3 minutes with lights, AC and radio on, dropped down to 11V. Turned off engine. Took alternator out and had it bench tested at NAPA. They said it was fine. As a test, went to a Ford salvage yard and picked another one up that was also tested fine, put that one in. Same exact issue.
Checked all my fuses, the box in the engine and the panel in the cab, everything checks out fine. Seems that the alternator charges fine, until it starts to heat up. At the top of the morning, I can drive for about 20 minutes before the voltage drops.
Any thoughts? Thanks in advance for the help!
Phoo
Old Jul 26, 2010 | 02:47 PM
In many late model vehicles , the ECA controls when and how much the alternator will put out. A good starting point would be to determine if the ECA is sending the signal to the alternator . ,,,,,,,,,,,,,,hanky
bluzzer
Dec 13, 2018 08:56 AM
makuloco2000
Mar 29, 2014 08:57 AM
lisam
Apr 20, 2009 01:41 AM
djporche
Mar 12, 2009 11:09 AM
DannyC188
Jan 4, 2008 11:05 AM
