rough idle 2.0 Split Port
Old Oct 14, 2005 | 02:48 AM
gearyoil's Avatar
Default rough idle 2.0 Split Port
I recenty bought a 2000 Focus Wagon with a 2.0 Split Port engine . It has auto trans. It has 120 K miles but is dry underneath and is not an oil burner. It does however, idle rough especially when the engine is cold. It improves when it warms up. It doesn't miss or cut out and accelerates fine. When you lay your hand on the valve cover you can feel the vibration. Also in the steering wheel. As I said, when it warms up it greatly improves. Exhaust sounds normal. Any ideas? Thanks.
Old Oct 19, 2005 | 02:32 PM
josser's Avatar
Default RE: rough idle 2.0 Split Port
i would start with the basics, put fuel injector cleaner additive in your gas and go from there. if it improves then i would say your car needs a major tune up and either injectors cleaned or new injectors.
Old Oct 19, 2005 | 10:52 PM
hockeyhitman69's Avatar
there is a tsb for this concern at it states reprogam pcm with update and it works better but they all have some at idle
Old Oct 20, 2005 | 07:12 PM
gearyoil's Avatar
I'm going to try both suggestions. The cleaner will be easy, but the re-programing sounds more technical. I assume I'll have to take it to a FORD dealer. I assume tsb is technical service bulletin. What exactly is pcm? Thanks for your help.
Old Oct 26, 2005 | 12:54 PM
josser's Avatar
how did it go! did you get the problem fixed?
Old Oct 26, 2005 | 07:03 PM
pcm is powertrain control module used to be ecm before they change names for fun i think
Old Oct 26, 2005 | 10:57 PM
sorry got it confused the tsb is 04-24-10 rough idle is rear engine roll restrictor for debris not a reprogramming ...
Old Oct 31, 2005 | 02:50 AM
gearyoil's Avatar
Tried the injector cleaner. ( 2 bottles ) Didn't seem to help. Don't quite understand the last post. Is re-programing the computer still a possible option. I was going to my Ford dealership to see if they could do it.
Old Oct 31, 2005 | 08:17 PM
yes its a possibility but more likely to be the tsb problem
Old Nov 1, 2005 | 07:02 PM
gearyoil's Avatar
Took my Focus to the local Ford dealership today. I mentioned the service bulletin that said " re-program pcm " and they acted like they didn't know what I was talking about. They looked up 2 tsb's and said neither one would cause my problem. Could you tell me exactly what to tell them so maybe they can find the right information; dates , bulletin number or something. Thanks for all the help so far.
thalchak
Mar 20, 2013 11:42 AM
Plantman
Dec 27, 2009 04:54 PM
Olpapa
May 18, 2008 03:22 PM
Goliath
Sep 24, 2006 12:40 AM
duli
Dec 6, 2005 09:56 PM
