Fan switch problem 2003 expedition
Old Aug 8, 2010 | 04:28 PM
Tom Schlichting's Avatar
Default Fan switch problem 2003 expedition
Need help , the fan switch is only able to run on the highest setting number 4 speed. the first position speed setting had stopped working about a year ago but position 2, 3, & 4 still worked until recently when both 2 & 3 stopped but High #4 still works. Is my switch bad or is it likely something else and how do you go about fixing it. Thanks, tom
Old Aug 8, 2010 | 06:00 PM
The majority of the time when you have this problem , the resistor body usually located under the hood near the blower motor has a plug with 3-4 wires coming out of it and usually two screws holding it in place has possibly burned through one of the resistor circuits. The result is, only high speed with the blower motor since high speed is fed by a separate relay and not through the resistor assy. Fast & easy fix. ,,,,,,,,,,hanky
Old Aug 9, 2010 | 08:36 AM
Thanks Hanky, I'll take a look this evening. Is ther any way of testing if that's the cause or just get a new resistor and try it?
Old Aug 9, 2010 | 04:30 PM
I have played around with them and if you have a jumper wire you can bypass some of the resistors and the blower may work depending on which resistance you jump. Some resistor units also have a diode in them and that can also fail. In either event you can save a lot of time and trouble by purchasing another resistance unit, best from dealer parts dept, Get the right part the first time.
hanky
klb123
Sep 20, 2011 07:05 PM
APS612
Aug 21, 2007 07:22 PM
brewcrew
Feb 7, 2005 09:49 PM
skid2964
Jan 8, 2005 10:01 AM
