"check charging system" huh?
Old Aug 8, 2010 | 10:31 PM
Eaton01's Avatar
Default "check charging system" huh?
Its a 2005 F150 Lariat with 58,000 miles and I just bought it this week. I tested the 4x4 High for half a mile and about 15 minutes later the check battery light came on. But, in the bottom right hand corner of the gauges where it gives mpg/mile til E/ etc etc it said "check charging system." Can anyone tell me what this means? Its still under the dealer warranty so it wont cost me anything but I dont want to get fed a line of B.S. and only a temporary fix. I'd like to go in with some knowledge of the problem so I can get it fixed properly.
Thanks,
Eaton
Old Aug 9, 2010 | 06:25 PM
way2old's Avatar
For some reason the battery either is not being charged by the alternator, or the battery is just bad. Have them do a charging system check to see if the alternator is outputting the correct voltage and amperage. Also ask for a load test on the battery to see what the state of the battery is. They should load the battery to 1/2 the cold cranking amps and the voltage should not drop below approximately 9.6 volts. When load is removed, the voltage should go back above 12 volts very quickly.
mkburak
Jul 28, 2015 08:31 PM
Kelly G.
Jul 11, 2015 11:59 AM
Bonnieangel73
Jun 6, 2011 09:04 AM
rimo
Aug 13, 2009 08:08 AM
monie_love06
Jan 22, 2009 11:04 AM
