94 Ford Taurus Brake Problem...
Old Aug 16, 2010 | 10:01 AM
calc001's Avatar
Question 94 Ford Taurus Brake Problem...
1994 Ford Taurus 3.8L Engine
Hello
My dad and I are having a problem bleeding the brakes to his 94 Taurus. See, we had to replace a broken brake line (Front Driver Side Line) and just to be safe, bled all the lines. Now we have a spongy brake pedal and brakes that don't brake as well as they used to. I don't know if my dad missed anything because he doesn't have much experience with Anti-Lock Brakes. He had the car on while he bled the lines (I was pumping the brakes for him).
If you can give any tips, we would be very grateful!
Chris
Old Aug 16, 2010 | 06:55 PM
way2old's Avatar
Have him bleed the brakes again with the vehicle not running. Start at the farthest wheel away from the master cylinder (passenger rear) and work to the master cylinder. (driver rear, passenger front, driver front, master cylinder) Make sure the bleeder screws are closed before foot is removed from brake pedal.
Old Aug 17, 2010 | 12:13 PM
calc001's Avatar
Ok, when you said master cylinder, you mean bleed it by loosening the lines one at a time and bleeding them?
Old Aug 17, 2010 | 07:09 PM
way2old's Avatar
Pump the pedal up and slowly open the brake lines slowly on the master cylinder. Do each line the same. Bleed them the same as you do the wheels.
BornFree0708
Oct 9, 2014 06:56 PM
vibher
Apr 29, 2013 04:42 PM
jfburtonfan
Aug 23, 2008 11:42 AM
lordaji
Sep 6, 2007 11:44 AM
brownrd
Apr 27, 2006 12:14 AM
