P1132 fuel air metering
Old Aug 16, 2010 | 12:08 PM
Jack Hampton's Avatar
Default P1132 fuel air metering
Got a code p1132 says manufacturer control fuel air metering. Has anyone had this problem and a solution?
Old Aug 16, 2010 | 06:59 PM
way2old's Avatar
Here is the short version of the test.
P1132 - Lack of HO2S-11 Switch, Sensor Indicates Rich A HEGO sensor indicating rich at the end of a test is trying to correct for an over-lean condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit. Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
Old Aug 17, 2010 | 03:48 AM
Thank you very much. Will see what I can do now.
tcaswell0282
Jan 16, 2009 10:40 PM
Rooster89
Apr 22, 2008 05:22 PM
sgarcille
May 1, 2007 04:02 AM
