SHO A/C bypass
Old Aug 19, 2010 | 08:27 AM
norman's Avatar
Default SHO A/C bypass
Hello,
I have a 1996 Taurus SHO with a locked up A/C compressor and pulley bearing. I want to either install a shorter belt or remove the compressor with a shorter belt. The hub and bearing is like $300.00 Not doing that!!
HELP!!!!
Old Jul 17, 2011 | 01:23 PM
Spud's's Avatar
Exclamation A/C
Did you find out any thing i have 2005 taurus A/C locked up.need info ex.belt lengh to bypass have you had any luck I DON'T HAVE MONEY FOR COMP Thanks Any info app
Old Jul 17, 2011 | 01:25 PM
Spud's's Avatar
Unhappy A/C
any luck finding belt lenth
Old Aug 9, 2011 | 10:20 AM
rich4's Avatar
Default A/C
Did you find a belt, I was told to get the dimensions on a belt is to take a piece of rope the same diameter of the belt and run it around the pulleys to get a length and go to a good auto store and see if they can match the length.
harptaz
Jun 2, 2008 12:01 AM
scubarunner
Feb 24, 2008 09:41 AM
thejoker954
Jul 6, 2007 04:17 PM
jam68_2003
Sep 30, 2006 04:02 PM
CHILAND
Jul 4, 2006 01:04 PM
