non working cigar lighter
Old Nov 1, 2005 | 09:35 PM
danielswindells's Avatar
Default non working cigar lighter
hi people-first post. i am in the uk and have a 96/97 escort-anyways this can pretty much apply to most cars i suppose. my problem is that my cigar lighter does not work-mminor i know. the fuse is not blown and i replaced it and nothing...i tried a new top part to the lighter and still it doesnt work. i know i could try replacing the base unit-which i am going to try to do soon. but if that doesnt work-are their any suggestions as to what i could try?...it has not worked for some time-and before i got the car it was inoperable to.
Old Nov 3, 2005 | 07:39 PM
hockeyhitman69's Avatar
Default RE: non working cigar lighter
you said the fuse was ok but are you getting any power to the lighter check with a test light if you are well you know it is the base and if you have no power then you have a open circuit and will have to trace your wires to find it
Old Nov 5, 2005 | 04:20 PM
hi mate...thanks for the reply. sorry for asking silly questions but what do you mean by a test light?.
also....just out of curiosity today i had a look at the wires directly behind/connected to the lighter-hopefully this will make some sense. But basically their appears to be a plug with 3 small recessed prongs that you obviously push into another plug with 3 corresponding holes. I noticed when examining these that 2/3 prongs were fine but 1 of them was much shorter and therefore i suspect-broke. If this is the case would that be enough to stop the lighter from working?. thankyou
daniel
Old Nov 9, 2005 | 10:18 PM
yes that would do it and a test light is a pen looking tool with a point at one end and a clamp at the other end clamp goes to ground and point on power side and the little bulb lights up the circuit is ok
Old Dec 5, 2005 | 12:52 AM
justaskin's Avatar
How did it work out with the cigarette lighter?
I found out the other day that I needed to have my ignition turned on in order for mine to work. I was trying to run a pump to pump up the spare tire in the wagon.
fordguy1969
Aug 18, 2019 10:49 AM
Beartronix
Aug 21, 2008 05:40 PM
rooney1008
Dec 4, 2007 08:44 AM
RealFnCool
Oct 25, 2007 06:44 PM
FirstOnRaceDay
Jul 31, 2006 04:16 PM
