1985 6.9L runs rough
Old Aug 30, 2004 | 12:13 PM
superbeast's Avatar
Default 1985 6.9L runs rough
I have a 1985 F350 ,6.9L deisel that runs rough at ideal. It runs good when you accelerate. Could anyone please help.thank you.
Old Nov 2, 2004 | 11:11 PM
delb101's Avatar
Default RE: 1985 6.9L runs rough
it could be a cloged injector try running some fuel injector treatment mine did the same thing the shop told me i needed a new injector pump for 1000 dollars i ran injector cleaner through 2 tanks of fuel and problem went awaythat was over a year ago
Old Jan 31, 2005 | 08:52 PM
77fordhighboy's Avatar
Try new glow plugs and wires, also your fuel filter and air filter. if that doesn't fix it i would do a distributor, and if that ain't it i would do a coil. If it still ain't running right drive it over a cliff and get some insurence money for it!
Well good luck man!!!!!
Old Jan 31, 2005 | 09:43 PM
I'm thinking the same thing as delbe101.
It was my first thought
Old Nov 9, 2005 | 12:33 PM
creeperJack's Avatar
I have the same year,Check for a crimped fuel line.Check all fuel line connections.Make shure no air is getting in the fuel lines.When you cold start it do you let the motor kick down before you drive it?I have the 420 6.9 IH,and the only problems i have had were bad fuel line,bad injectors,bad glow plugs and a bad ground in the last 15 years.
Screenwriter
Dec 8, 2016 08:37 PM
goatsauce
Apr 15, 2013 08:32 PM
louchris
Nov 29, 2007 11:58 AM
Loum12
Mar 28, 2005 11:43 PM
