My Expo's Dying!!
Old Nov 6, 2005 | 07:31 PM
Renz01Expo's Avatar
Default My Expo's Dying!!
I bought a 2001 Expedition w/ only 43000 miles about 2 months ago. Yesterday just about all the important stuff just stopped woking, like the brake shift interlock, the rear a/c, and the power windows. Well that's all I figured out so far, the fuses are good accept the brake shift interlock keeps blowing. any help??????
Old Nov 8, 2005 | 01:55 PM
Patrick's Avatar
Administrator
Default RE: My Expo's Dying!!
are they all on that same circuit?
Old Nov 9, 2005 | 06:11 AM
Renz01Expo's Avatar
I'm gonna say yes, because it's a 5 amp fuse that blows, and for that 1/2 second that it's not blown yet, what's supposed to work does work, for now, everything is working since I put in a 30 amp fuse, but I still don't feel comfortable wit it. U know, My wife and daughter might get stuck out there someday call me and ask "What's a Fuse?".
Old Nov 9, 2005 | 09:43 PM
hockeyhitman69's Avatar
30 amp fuse wont fix the problem i would rather burn a fuse than fry something else up .if there is 4 things on that circuit put a 5 amp on each circuit then when the fuse blows you will know which circuit is the problem coming sounds like its shorted somewhere .you have to isolate the problem first
Old Nov 9, 2005 | 10:12 PM
Renz01Expo's Avatar
So more than likely there's a wire touching metal somewhere? How about the interior lights, they have a relay not a fuse on the inside fuse compartment, I'm wondering if that could be where it's coming from. I really think I should get a wiring diagram, don't you?
Old Nov 24, 2005 | 06:39 AM
frdtek05's Avatar
Pull the steering column shroud and follow the two wires coming from the bottom of the shift lever. I don't know if the Trans OD button is on the same circuit but those wires shorting to metal parts on the steering column cause havoc on Excursions and Postal Explorer trucks.
Old Nov 25, 2005 | 02:19 AM
Ive seen alot of problems with the lil spaghetti wires, on the OD switch chaf on the column an short out as well.
Old Jul 17, 2006 | 05:00 PM
Renz01Expo's Avatar
[color=#000099]Well the expo finally died, and so young, only 45,000 miles. The dealer never had the recall fixed so I woke up one morning only to find it totally in flames!!! It was gone. That was my first Ford and will be my last, I should of stayed a Chevy guy.....Ask if you want any pics....
Old Aug 15, 2006 | 07:33 PM
2THPIC's Avatar
pic are all ways good to look at, if not just to say oooooooooooooooo that sucks
Old Aug 15, 2006 | 08:07 PM
94 4x4 ranger's Avatar
Lesson to be learned they told you to NOT to put in that 30 amp fuse insted of a 5 amp.Quote:hockeyhitman69 Date 11/9/2005 7:43:53 PM
2THPIC
Jan 2, 2020 11:37 PM
desinez
Apr 16, 2007 04:23 PM
dixie
Mar 23, 2006 11:21 AM
jasonv
Dec 19, 2005 12:08 AM
mrdec9
Dec 12, 2005 10:24 PM
