escort fan switch
Old Sep 2, 2004 | 09:45 PM
brewcrew's Avatar
Default escort fan switch
I can't find the fan swithc aon a 96 escort. the fan won't kick on when it is supposed to. any help would be aprpeciated.[sm=smiley22.gif]
Old Nov 1, 2004 | 07:39 PM
roundman's Avatar
Default RE: escort fan switch
check the fuses to make sure it hasn't blown a fuse, not sure they have a switch except for the themostatic one that tells it when to come on and go off.
Old Feb 5, 2005 | 02:26 AM
eL Dude's Avatar
If you have A/C, turning that on should cause the fan to come on. Also, unplugging the temp sensor should make it come on. If neither one happens check for 12V on the plug to the fan.
(Don't stick your hand in there with the engine running. Start it after you've unplugged it)
If no 12V, you may have a blown fuse, bad relay, corroded plug.
If 12V, time for a new fan.
Old Feb 7, 2005 | 09:49 PM
Check here for diagrams, component locations, and help troubleshooting. GOOD LUCK
http://www.autozone.com/servlet/UiBr...rGuideYMMEYear
klb123
Sep 20, 2011 07:05 PM
Tom Schlichting
Aug 9, 2010 04:30 PM
APS612
Aug 21, 2007 07:22 PM
skid2964
Jan 8, 2005 10:01 AM
