oil in the air intake tube
Old Nov 18, 2005 | 02:35 AM
elbert's Avatar
Default oil in the air intake tube
'98 3.8L Windstar 112k
I get quite a bit of oil (about 2 spoonful) that accumulate in the inside of the air intake flex tube next to the throtle body. I also get a little bit of oil the on the throtle body tube. I believe this may be related to why I'm getting a P0306 (misfire on cylinder 6) error code. I have replaced the EGR valve but I'm still getting oil in the air intake chamber. Any ideas why I'm getting so much oil in the air intake tube?
Thanks in advance.
Old Nov 19, 2005 | 01:33 AM
frdtek05's Avatar
Default RE: oil in the air intake tube
Sounds to me like blowby gasses forcing oil and vapors into the fresh air inlet. It could be excessive blowby, meaning worn piston rings but I would fork out 6 bucks for a new pcv valve and inspect the tube closely for collapse, leaks, soft areas.
The oil making its way into the intake stream can cause a misfire for you by fouling the spark plugs. Pull the #6 plug and I'd be willing to bet you got some ugly build-up there.
RedEric
Apr 26, 2015 08:28 AM
RedEric
Apr 25, 2015 12:27 PM
Vlaj
Feb 3, 2010 08:48 PM
tcaswell0282
Jan 16, 2009 10:40 PM
racespeed200
Jan 17, 2006 02:06 AM
