Transmission shift Problem
Old Sep 14, 2004 | 05:47 PM
jmbetts's Avatar
Default Transmission shift Problem
2000 Ranger XLT, Auto w/47k miles. Vehicle starts out with a slight delayed shift between 1st and 2nd gear. eventually popping out of overdrive. When I start the vehicle and turn off overdrive, It drives a little better, but that shift between 1st and 2nd delays again and a harsh shift happens and the overdrive light flashes. Had the transmission fluid changed and the filter was supposed to be changed with that. Fluid I was told was clean. Was told it could be:
1) Vacuum hose leak
2) Electronic Shift Control Module
3) Some of the bands in the tranny
4) Faulty Vacuum Diaphram in tranny (but book says this applies to 94/95 Ranger)
Anyone have any ideas
Old Sep 15, 2004 | 03:08 AM
grampztoyz351's Avatar
Default RE: Transmission shift Problem
I had about the same experiance with a Contor awhile back it turned out to be the electronics,we had to have diagnostics run on it sensor in the trans was the problem. I'd take it in if it was mine. It only cost about $200.00 to have fixed,no problems since.
Old Sep 15, 2004 | 04:28 AM
jmbetts's Avatar
Thanks, I will have that checked out
green t
Nov 16, 2008 08:08 AM
hookset
Feb 15, 2008 08:11 PM
06limited
Dec 2, 2006 12:35 AM
beads8
Apr 26, 2006 10:56 PM
kiji
Feb 20, 2006 09:58 PM
