1996 contour code 171 system too lean
Old Dec 1, 2005 | 12:40 PM
c2321's Avatar
Default 1996 contour code 171 system too lean
have a 1996 contour
engine light keeps coming on, got a reader and code 0171 is popping up
System too lean (Bank 1)
about 70000 miles on it.....if anyone can give me a few clues where to start it would sure be
appreciated !!!
also hear like a loud rattle usually when first started.....looks like a cover for the timing chain??? rattle appears to come from there
doubt the 2 things are related?????
Old Mar 5, 2006 | 02:07 PM
c2321's Avatar
Default RE: 1996 contour code 171 system too lean
I think the noise....rattling type noise is caused by low R-134 ?!?
gets better when I add to the a.c.
but still getting the warning about 1 bank being to lean
adding inj. cleaner with most fillups but code keeps coming back
anyone know why???
Old Mar 6, 2006 | 05:37 AM
gdub520's Avatar
timing chain rattle was a v6 contour problem on the 95 model...something about when the oil was allowed to settle after the car had been sitting awhile...would occur mostly on cold start and go away in a second or two...the fix was supposed to have taken place for the 96 model yr i believe
as far as the code goes, could be the o2 sensor or fuel injector???
Old Mar 29, 2006 | 12:13 AM
frdtek05's Avatar
po171-lean condition bank 1.
90 percent of the time is caused by a vacuum leak. Look for collapsed or broken vacuum hoses or a leaking intake manifol gasket.
In most cases a malfuntioning o2 sensor will trip a code specific for the sensor itself.
Old Apr 5, 2006 | 12:55 PM
c2321's Avatar
thanks very much
I can sure look for some vacuum hose problems !!!!!
may the wind be at your back !
devmanclearh2o
Jul 31, 2009 07:11 PM
jeffandteneka
Feb 16, 2007 09:58 AM
jrminiquad
Jan 15, 2006 03:56 PM
palmateer
Apr 22, 2005 05:00 PM
