still no power to fuel pump
Old Dec 8, 2005 | 08:37 PM
elsanyo's Avatar
Default still no power to fuel pump
ok is there anyone out there that can tell me if there is a relay or fuse somewhere between the ignition switch and the inertia switch? Maybe I'm looking in the wrong place .
Old Dec 17, 2005 | 09:54 PM
elsanyo's Avatar
Default RE: still no power to fuel pump
well thanks guys you were so much help ( not )I found the problem on my own short in wiring harness and hot spot in fuel pump making it work infrequently .
Old Dec 21, 2005 | 10:17 AM
Cool , glad to hear you got it going , also their bad about having a problem with the connecter plug going to the top of the tank ,
see quite a few that the plug has melted from excessive heat from a bad connection, usually you can get away with just cleaning up the connecter an squezzing them a little tighter ,also on the ground side of the plug Ive found loose that will give you a intermitt start .
make sure you use some di-electric grease on the terminals
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
ryche
Feb 27, 2015 01:35 AM
Spaznaut
May 24, 2014 02:10 PM
daveranger
Aug 10, 2007 08:51 AM
