towing capacity
Old Dec 16, 2005 | 08:12 PM
yorttroy's Avatar
Default towing capacity
I have a 99 ford expedetion with a 5.4 auto tran and 3.55 gears what is the towing capacity thanks for the info
Old Jan 3, 2006 | 07:18 PM
oregonn8v's Avatar
Default RE: towing capacity
yorttroy:
I looked in my owners manual, and it does not show specs for a 5.4L with the 3.55 Rear Axle Ratio (that ratio is only shown on the 4.6L) but here is the full breakdown. Mine is a '97 Eddie Bauer and they may have made some axel ratio changes in those two years.
ENGINE / Rear Axel Ratio / Tire Size / MAX GCWR / MAX Trailer Weight
4.6L (4X2) / 3.31 / 16 in / 11,000 lbs / 5,900 lbs
5.4L (4X2) / 3.31 / 16 in / 12,000 lbs / 6,700 lbs
5.4L (4X2) / 3.73 / 16 in / 13,500 lbs / 8,000 lbs
4.6L (4X4) / 3.55 / 16 in / 11,500 lbs / 6,100 lbs
4.6L (4X4) / 3.55 / 17 in / 11,000 lbs / 5,500 lbs
5.4L (4X4) / 3.31 / 16 in / 12,000 lbs / 6,400 lbs
5.4L (4X4) / 3.73 / 16 in / 13,500 lbs / 7,900 lbs
5.4L (4X4) / 3.73 / 17 in / 13,000 lbs / 7,400 lbs
I don't know if this will help you out or not, but it may get you pretty close.
jpitura
Dec 15, 2006 09:30 PM
paulwillett8
Nov 6, 2006 05:16 PM
paulwillett8
Nov 6, 2006 12:48 PM
rhennosy
Sep 26, 2005 02:55 PM
sprig
Jul 18, 2005 09:16 PM
