'01 Sport Trac front brakes issue
Old Dec 17, 2005 | 11:09 PM
MooTony1994's Avatar
Default '01 Sport Trac front brakes issue
I had new front brake pads put on about 5 months ago. The brakes smelled hot for awhile after they were done and then quit smelling. Last week I had them checked again because they were squealing like crazy all the time I was driving. The drivers side front brake was dragging - he put new brake pads on again thought it should take care of the problem. I picked it up yesterday - it stopped squealing but same side is smelling hot again. He says there may be a problem with the ABS. Does anyone have any suggestions - I am going to have it looked at again on monday - he says it must be the ABS.
Thanks,
M in Missouri
Old Jan 2, 2006 | 12:07 PM
Default RE: '01 Sport Trac front brakes issue
Sounds like the front brake Caliper may be sticking, causing the brake pads to drag , an having constant pressure on them.
Yes they will be hot an smell, in effect your riding around with the brakes lightly applied
This is a very common problem, you can not always just install a new set of front pads, an call it a Brake Job.
explorerman
May 10, 2016 11:56 AM
Towguy76
May 22, 2013 12:01 PM
only1bigdaddyo
Apr 28, 2013 06:26 PM
murray46
Sep 30, 2012 09:47 PM
sonic195060
May 2, 2007 12:03 AM
