99 Windstar engine noise
Old Dec 30, 2005 | 04:52 PM
393c stroker's Avatar
Default 99 Windstar engine noise
I'm working on a 99 3.8 Windstar. It has a squealing noise on cold starts, sometimes while it's warm, near the front of the engine. I listened with a stethoscope and decided on a water pump, after replacing the belt. Neither part helped. I took the belt off, and it does it with it completely off. Is it something in the timing cover? Any help will be greatly appreciated. The timing cover looks like a bear, the pump was bad enough for me. Thanks.
393c Stroker
Old Nov 4, 2006 | 12:02 AM
thaas58's Avatar
Default RE: 99 Windstar engine noise
Check the camshaft position sensor. The bearing in that part will squeal when it goes bad. It is not driven by the belt.
Old Dec 2, 2006 | 01:23 AM
thaas58's Avatar
http://www.automotivehelper.com/topic232834.htm
This guy says the fuel injection synchronizer is beneath camshaft position sensor. This part has a bearing that will squeal and chirp loudly and will drive your wife to threaten you with divorce if you don't get it fixed, LOL!
Here's the post:
If that noise is a sort of metallic chirping sound coming from the timing cover area and it is not the serpentine belt, or any of ancillary pulleys than it most likely is the fuel injection synchronizer. This is actually underneath the cam position sensor. It is not too difficult to replace (part number xf2z-12a362-aa at Ford dealer lists for $110.) but does require a factory special tool to align when re-installing.
ranshells
Jan 14, 2011 11:13 AM
jwlsale
May 2, 2009 02:05 PM
WindstarWorkHorse
Feb 26, 2008 11:54 AM
johnnypro
Aug 14, 2007 06:52 PM
Dave
Jun 2, 2005 02:02 PM
