87 Bronco II Brake Problem
Old Dec 31, 2005 | 01:36 AM
Woodsman's Avatar
Default 87 Bronco II Brake Problem
My brakes are very spongy when I press the brake pedal, pedal goes almost all the way to the floor. Also, the brake pads on the drivers side front keep slipping off, the anti-rattle clip has fallen off and I am going to replace. The claipers are only 3 months old and I replaced the master cyclinder today. I have bled and re bled the system and the sponginess and the pad slip still continues. Do I have a sticking or seized claiper or a bad brake power booster unit? Or is my whole problem due to the missing anti-rattle clip causing pad slip which is interferring making he brakes spongy?
Old Jan 1, 2006 | 05:29 PM
Default RE: 87 Bronco II Brake Problem
This is a very odd one , even with the brake clip gone your pads should not slip off , not real sure what you mean by slipping off ? , is it possible you installed the wrong sides of the brake pads , you should have an inner an outer pad , normally one is smaller then the other.
If the brake pad is falling out then yea you will have a low pedal as theres nothing for the piston to press against
Also one thing you might want to try is to adjust your rear brakes , usually when theres a low pedal on these old Fords , I have found the rear brakes way outta adj.
Good Luck , let us know what you find , this one is interesting
Old Jan 1, 2006 | 06:55 PM
Woodsman's Avatar
Turns out it was a completely destroyed outer bearing, I hadn't noticed the play in the roter and it wasn't making noise when spun. Once I got it out it took awhile to get all the metal srapnal off everything. What was left of the bearings just fell out. the outer spindle nut wasn't even threaded on and was shot. The rotor had so much play in it the caliper couldn't compress with all the wobble, thats why the brake pad kept slipping off. WHen I say slipping I me it was darn near ready to throw the shoe.
Thanks for the input.
Woodsman
Old Jan 2, 2006 | 06:44 AM
yeppers , that would do it ----------------------------
vibher
Apr 29, 2013 04:42 PM
94Bronco
Oct 9, 2010 11:16 AM
noonrock
Jan 13, 2009 09:00 AM
69cutlasskid
Jun 26, 2007 10:27 PM
riska720
Oct 26, 2005 04:20 PM
