Surging Motor
Old Jan 11, 2006 | 12:06 AM
hardrock96's Avatar
Default Surging Motor
I have a 2000 Taurus that runs good while driving,but at Idle the engine surges.Anyone have this problem or is there anyone that knows what will cause this.Any help would be great.
Old Jan 17, 2006 | 12:54 AM
bosshoss's Avatar
Default RE: Surging Motor
I think that there is a TSB for a inncorrectly installed cam position sensor the dealer should be able to help with the info
Old Sep 26, 2006 | 10:19 AM
TYSONJR5's Avatar
TRY YOUR IDLE AIR CONTROL (IAC VALVE)
Old Oct 22, 2006 | 05:49 PM
92_Taurus_LC's Avatar
I have a 92 Taurus that's doing the same thing... it only does it when it's cold outside, The battery light will blink and will putt as if it wants to stall...It finally stalled the other day, and I couldn't get it to start back up at all... the battery tested 100% healthy, so I'm not quite sure what the problem is... sugesstions are appriciated...thanks
Old Apr 28, 2009 | 05:34 AM
tomtom34's Avatar
i've got a 94 150 and it does the same thing. its fine after it warms up. But that initial start it will idle up maybe 600 then almost die and continously do that. but if i keep giving it gas its fine. let me know if you find a solution
Old Apr 28, 2009 | 07:07 AM
gabe355's Avatar
Tyson is right, all the ford have that iac problem.The alternator light only turns on when you rev too low.
87Mojo
Jun 4, 2019 05:41 PM
spooledup
Dec 7, 2005 04:57 PM
spooledup
Nov 19, 2005 06:13 PM
MyBabyDoll
May 5, 2005 04:05 AM
