thunderbird belt
Old Jan 21, 2006 | 01:51 PM
davidthunder's Avatar
Default thunderbird belt
hey sup all, my ac compressor siezed, the pully is stuck, i just wanna get rid of the whole compressor, just wanna know if it is possible using a smaller belt, if so, if someone knows the belt size thankyou, its a 95 thunderbird v6, the compressor is on the top
Old Jan 27, 2006 | 10:02 AM
Old FE Buzzard's Avatar
Default RE: thunderbird belt
I've been there. As far as I can see it, there is no way to get around having a compressor there. I have a '93 SC that siezed the compressor that took the clutch/pulley assembly with it. You should have no problem getting one from the junk yard. I on the other hand had a nightmare locating one since the SC has a wider pulley than the regular 3.8 or 5.0. If you don't want to get involved with making the AC work, just leave the clutch connector off and use the compressor as an idler.
maiden_fan
Mar 26, 2007 01:06 AM
Jarco98
Aug 5, 2005 04:13 PM
foxyford83
Jan 23, 2005 04:18 AM
billy jolliff
May 17, 2004 03:35 AM
ndn1fan
May 8, 2004 10:38 PM
