Starting Problem
Old Nov 10, 2004 | 05:18 PM
DavidR's Avatar
Default Starting Problem
I have a 1994 Ranger that will start every time I try but almost immediatly dies. I have replace the fuel filter recently but other than that everything else on the fule system is factory stock. Once after it started I quickly work the throttle and it continued to run very roughly then died when I stoped.
Any ideas?
David
Old Nov 29, 2004 | 02:43 PM
ratboy's Avatar
Default RE: Starting Problem
You may want to check your O2 sensors. I think there are two. one on the manifold and one after the catalytic convertor. They control the mixture of O2 and Gas that your computer allows.
Old Nov 29, 2004 | 03:19 PM
DavidR's Avatar
I thought I should post a followup and let everyone know what I found to be the problem.
A spider had built a nest inside the MAF. Cleaned out the nest and the truck runs fine.
Thanks for the responce.
DavidR
FL3471
Mar 9, 2013 02:45 AM
stevedoo1
Mar 1, 2006 10:28 PM
Roanbadger
Dec 20, 2005 03:40 PM
moto318
Dec 2, 2005 04:17 AM
MooTony1994
Jul 26, 2005 03:03 PM
