Stereo removal
Old Jan 26, 2006 | 11:46 PM
05WhiteEB's Avatar
Default Stereo removal
Does anyone know how to remove the radio from a 05 EB Expiction want to install a Satelite fm modulator....Thanks Joe
Old Jan 28, 2006 | 09:29 PM
hockeyhitman69's Avatar
Default RE: Stereo removal
SECTION 415-01: Audio Unit 2005 Expedition/Navigator Workshop Manual
REMOVAL AND INSTALLATION Procedure revision date: 10/28/2005
Audio Unit Printable View (62 KB)
Removal and Installation
CAUTION: On vehicles equipped with a CD6 audio unit, interrupting battery power within 30 seconds of repowering will damage the audio unit. To prevent audio unit damage, do not disconnect the battery (or audio unit), reconnect the battery (or audio unit), and then disconnect it again within 30 seconds.
Vehicles with column shift
Remove the instrument cluster finish panel. For additional information, refer to Section 501-12.
Vehicles with floor shift
Remove the instrument cluster center finish panel. For additional information, refer to Section 501-12.
All vehicles
Remove the screws and grounding plate.
NOTE: Standard audio is shown, others are similar.
Disconnect the audio unit antenna lead-in cable and the audio unit electrical connectors, and remove the audio unit.
To install, reverse the removal procedure.
Old Jan 31, 2006 | 08:06 PM
05WhiteEB's Avatar
Great info but can u tell how to remove dash trim without damaging .I dont have a manual
Old Feb 3, 2006 | 09:08 PM
frdtek05's Avatar
Most Trim pieces are held in with clips attached to the back side of the peices. Tug lightly(sometimes a little more than lightly) only after you've looked for visable screws.
Wagney
Jun 15, 2017 10:01 PM
Chantelle
Feb 10, 2012 11:34 AM
jidai
Jul 12, 2005 01:40 AM
goldfingerrd
Feb 1, 2005 06:26 AM
Foxy_72
Nov 8, 2004 02:48 PM
