ignition problem
Old Jan 28, 2006 | 07:11 PM
krazydawg40's Avatar
Default ignition problem
replace the switch on a 95 thinderbird still nothing happening any suggestions thanks is there something loose in the colum thanks
Old Mar 28, 2007 | 04:58 PM
Default RE: ignition problem
First check take off and clean cattery cables and terminals and put back on. Then check battery has power. Then disconnect a battery cable again and remove starter to test it. If starter is OK put it back and cable back on. Next check fuses and fusible links. If it doesn't crank - do you have power? Enough power for headlights? Does starter click under hood of car?
damonlathe
Apr 11, 2007 08:11 PM
SleeperFan
Feb 9, 2007 01:05 PM
bighueyy2k2
Oct 12, 2006 10:58 PM
riska720
Oct 26, 2005 04:20 PM
highpowerd2003
Aug 29, 2005 10:56 PM
