Push button 4x4 on 90 bronco
Old Feb 13, 2006 | 09:41 PM
slammr316's Avatar
Default Push button 4x4 on 90 bronco
Don't you just hate when you get 17in of snow and your 4x4 don't work? I push the button and hear some kind of solenoid clicking but it just wont engage. any suggestions? Please reply.
Old Dec 16, 2007 | 10:01 AM
cpubuilder's Avatar
Default RE: Push button 4x4 on 90 bronco
I don't know why no one replied to you, this is probably fixed or long gone by now, but I have the same problem. If the solenoid is engaging at the transfer case (easiest way to tell is the noise it makes or see that the front shaft is turning, then it is you hubs. Mine is the hubs, trying to look at manual ones or something.
Old Nov 4, 2008 | 06:42 PM
bryanb70's Avatar
I have a 90 bronco push button 4x4. It does the same thing, but worse in the cold. I believe it's the motor not a solenoid. Still haven't changed mine, but if i keep trying it finally it works.
Old Jan 11, 2009 | 02:41 AM
The motor is usually more prone to go. Hubsmight notlock right without it?
55blue
Jul 3, 2013 07:33 AM
sludgemonger
Jan 12, 2011 10:42 PM
Thebeast
Feb 13, 2008 07:41 PM
rangerr731
Nov 23, 2006 12:49 PM
RayeAlmighty
Oct 2, 2005 06:20 PM
