'05 Taurus Computer Module Location
Old Feb 20, 2006 | 09:50 PM
stanshepp's Avatar
Default '05 Taurus Computer Module Location
I just bought a used Taurus and I do not know the keyless entry code as programmed by the factory. It is supposed to be located on the COmputer Module, but I do not know where that module is located. Under the hood? Under the dash? Driver's side? Passenger's side? In the trunk? Does anyone know? If so, could you please tell me?
Thanks!
Old Apr 13, 2006 | 03:15 PM
WASLYH's Avatar
Default RE: '05 Taurus Computer Module Location
[8D]
i hope i can help...had the same problem( see all my posts 2day)
the 'puter should be under and to the left of the steering column...
get under there w/flashlight and look on the right side...it should be there
little white tag with 5 digit code...
Old Apr 14, 2006 | 06:59 PM
stanshepp's Avatar
Thank You! Thank You! Thank You! That worked! Thank You!
Old May 12, 2006 | 04:29 PM
WASLYH's Avatar
been gone 4 awhile...no problemo...glad it turned out 4 u..
mnpc7v7
Apr 29, 2017 11:22 PM
MarcEMarc
Mar 30, 2009 03:48 PM
cmaidana
Jan 9, 2009 06:49 PM
iward3
Dec 28, 2008 11:12 PM
Country Man
Nov 6, 2008 11:08 AM
