67 Mustang brake lights not working
Old Mar 7, 2006 | 02:40 AM
traumadog29's Avatar
Default 67 Mustang brake lights not working
Okay, I removed my rear tail lamp assamblies to primer the body. I reinstalled the tail lamps and now my brake and back up lights will not illuminate. The parking lights and turn signals still work fine. I replaced the brake light switch under the dash, but still they do not work. Any ideas? Are the tail lamp assamblies suspose to be grounded to the body of the car or are the gaskets suspose to insulate them from grounding? Thanks.
Old Mar 9, 2006 | 05:38 PM
Duffs302's Avatar
Default RE: 67 Mustang brake lights not working
I can't help but try here http://www.mustangforums.com/forumid_18/tt.htm
Old Apr 19, 2006 | 10:05 PM
jimnstub's Avatar
The body of your Mustang is the ground for all eletrical systems. The gaskets prevents the tail light housing from rubbing on the tail panel and causing chipped paint and rust. The tail light housings are grounded through the 4 housing mounting bolts inside the trunk. I assume primer/paint is thick enough that it is preventing a good ground. Try jumping a wire from the housing bolts to a good contact in the trunk. Jim G.
bmarnall
Mar 1, 2010 09:33 PM
cu101man
Feb 1, 2010 11:35 AM
twoody72
Jul 5, 2009 07:53 PM
caper74
Apr 25, 2008 01:11 AM
