F250 ground problem...?
Old Dec 2, 2004 | 05:33 PM
bbnx's Avatar
Default F250 ground problem...?
The left rear blinker on my F250 started "fast blinking" today.... It still clicks inside the truck, but the blinker does not work outside. The dash indicator does blink but also very fast. I checked power at the bulb connector and my test light blinked fast too... I'm thinking a ground issue with that connector but am really just guessing.
Any other ideas or suggestions will be greatly appreciated.
Thanks!
Old Feb 5, 2005 | 02:17 AM
eL Dude's Avatar
Default RE: F250 ground problem...?
I'm thinking Lighting Control Module.
What year is it?
Old Feb 7, 2005 | 09:44 PM
Also remove the leftside turn lights and check OHMs, maybe a light is shorted internally or very low resistance.
Old Feb 7, 2005 | 11:44 PM
Should have said that if the rear is blinking the problem will probably be in the front. Don't forget to check the side marks if any.
Old Jun 7, 2005 | 06:40 PM
pakus's Avatar
You have a bulb out, the F250 does not have a lighting control module. Also while the codition is occuring, try wiggling the hazard button on top of the steering column. This switch will get gunk in it and cause the concern. If all bulbs are ok, you may have to replace the multifunction switch. Ford SMT
Old Jun 7, 2005 | 09:13 PM
Check for a short in the trailer connector.
Old Jun 11, 2005 | 10:20 AM
solo_one's Avatar
Had the same problem on my Ranger, its a bad bulb.
timnoserider
Jun 13, 2013 07:27 AM
dishbound
Nov 4, 2010 07:33 AM
sean01
Jul 11, 2010 09:33 AM
eagront
May 30, 2009 02:04 PM
jeninejessica
Jan 7, 2006 12:41 AM
