20's on a ford fusion
Old Mar 13, 2006 | 08:34 PM
jordan1560's Avatar
Default 20's on a ford fusion
does anyone kno what type of modifacations would need to be done to make 20 inch rims fit on a ford fusion?
Old Mar 15, 2006 | 09:24 PM
sean08's Avatar
Default RE: 20's on a ford fusion
maybe you can ask someone from your dealership on what you need to do with your wheels. they might be able to help and give you some ideas.
Old Apr 21, 2006 | 12:03 AM
SlickyBoyz55's Avatar
I just bought a Fusion SEL the other day. Apparently California Concepts is dressing some of these up with 20 in. wheels, lowering kit and tinted windows. The car looked sharp. I will settle for the V-6 SEL that I bought for now.
Old Apr 21, 2006 | 08:09 PM
fordfusionduder's Avatar
I've never heard of 20's on a ford fusion. But they would look absolutely sick. I honestly don't think they would fix the stock setup.
Old May 12, 2006 | 10:57 PM
Ranchoman's Avatar
I just saw a Fusion with 3d Carbon ground effects and 20's on it and it was bad @#*
Old Nov 4, 2006 | 02:24 AM
RNGMSTR's Avatar
I test fitted a set on my 2007 AWD, they fit great with room to spare. Now I just have to decide what wheel I want to go with. I am also installing the eibach 1.6" lower springs and will still have plenty of room. Bigger wheels, smaller sidewall tires, very close to the same outside diameter as the stock 17's.
Old Mar 20, 2007 | 04:35 PM
msu_fan16's Avatar
do you think it will fit on a 2006 front wheel drive?
Old Mar 28, 2007 | 09:15 AM
djtubbz983's Avatar
I do have a Fusion with 20 inch chrome rims and you dont need any mods to put it on, But you will need low pro tires like 235 or 245/45 20...
Old Jun 6, 2007 | 04:09 PM
Ceace's Avatar
There is no problem putting 20s on a Fusion. Actually, if you drop it 1.6 inches, it will look better. Here are some bad *** Fusions with rims from Fordfusionclub.com.
http://www.fordfusionclub.com/index.php?topic=44125.0
Old Jun 29, 2007 | 02:57 PM
thewolfman456's Avatar
Yeah, there is. If he does it, he becomes a ricer.
