rear main
Old Dec 11, 2004 | 01:23 AM
hillbillydad's Avatar
Default rear main
got a 78 supercab 1 ton. has a 400. and the rear mains outta it. whats the best way to go about replacing it?
thanks.
Old Dec 13, 2004 | 02:51 AM
grampztoyz351's Avatar
Default RE: rear main
The easiest way to change it would be to drop the trans, you may want to find a trans jack to give a helping hand.
Old May 17, 2006 | 02:21 AM
masterdon46's Avatar
EMAIL MY HUSBAND HE HAD TO REPLACE 3 REARS AFTER YOU DROP YOUR TRANS YOU HAVE TO USE THE PLASTIC COVER TO HELP INSERT IT ANS YOU SHOULD USE GASKET SEALER IF YOU PUT IT IN DRY YYOU MAY TEAR THE RUBBER AND IT WILL LEAK AGIAN
Old May 17, 2006 | 10:25 AM
if He is installing the seals correct an there still leaking , its possibly that the main brgs are worn out allowing excessive play in the Crankshaft.
sumrbeachbum778
Feb 22, 2008 09:25 PM
pilotjock
Sep 1, 2007 12:10 PM
fomocoguy
Jul 7, 2007 08:59 AM
1984/351W
Mar 20, 2006 04:57 AM
styln63
Jul 10, 2005 03:27 PM
