water temp and oil pressure guages
Old Apr 1, 2006 | 11:04 PM
hunterman's Avatar
Default water temp and oil pressure guages
Just purchased a 1996 GT with 4.6 engine. Using Mobil 1 and Fram filter and just had cooling system flushed. Replaced the thermostat with OEM due to guage reading over the mid line and hot. Now the oil pressure guage and water temp guage are fluctuating. The water temp goes almost to the red line and then returns to right above mid range within a couple of minutes. I turned the heater on and it had no affect on the temp reading. The oil guage fluctuates, regardless of rpm, from one quarter to middle to just over mid point. The fluid levels are good. Does anyone have a suggestion to correct. The mileage is 72,000 and runs strong. Thanks
Old Apr 5, 2006 | 11:55 PM
Duffs302's Avatar
Default RE: water temp and oil pressure guages
The water guage on the Mustangs are not good at all mine and others do that, best to get a after market one to get a good water temp. As for the oil guage mine was replaced at the dealer and it only moves when I start it up, so again replace it with a after market guage. Just saying.
Or if you can hook it up to a computer to see if the guages are right or not.
Old Apr 8, 2006 | 06:49 PM
waldoranger's Avatar
could that happen on a ranger?
Old Apr 9, 2006 | 09:17 PM
Duffs302's Avatar
ORIGINAL: waldoranger
I haven't heard of a Ranger with that problem.
Old Apr 15, 2006 | 10:17 PM
hunterman's Avatar
THANK YOU. THE TEMP COMING OUT OF THE RADIATOR IS 160 DEGREES AND OUT OF THE BLOCK AT 202. THIS SEEMS GOOD ACCORDING TO EVERYTHING I HAVE READ. I WILL REPLACE THE GUAGE.
Old Apr 21, 2006 | 12:52 AM
Duffs302's Avatar
Hope it works out for you.
BCinPhx
Jun 30, 2009 11:18 AM
ddareaustralia
Dec 27, 2008 04:12 AM
Davetheslave
Oct 18, 2008 05:25 AM
jasoncrowley
Jun 7, 2007 08:02 PM
jtanker1775
Feb 25, 2006 08:38 PM
