Cruise O Matic Help
Old Apr 17, 2006 | 02:28 PM
jkostur's Avatar
Default Cruise O Matic Help
I have a problem with my Galaxie, Its a 1964 Galaxie 500 with the 390 and Heavy Duty Crusie O Matic Tranny.
My Problem is I changed the tranny pan gasket, Filter, Fluid because of a Leak. The car has only 40132 Miles but has sat for many years so everything is drying out. Ok since I changed the tranny gasket the car goes into all gears just fine she runs good drives good BUT will not auto shift?????. Is there a vacum line someware that i knock loose or broke. Any Info would help. Thanks[quote]
Old Mar 1, 2007 | 05:48 PM
Default RE: Cruise O Matic Help
You mean will not downshift or shift up through the gears? Have you been manually shifting up? If so, it may have some debris or gummed-up fluid inside in the servos.
CaptJack101
Jun 25, 2009 05:35 PM
rigohu
Aug 28, 2008 07:24 PM
rigohu
Aug 18, 2008 11:49 AM
unclebobsuncle
Apr 23, 2008 11:58 PM
audioguy
Nov 21, 2005 11:56 PM
