03 excursion radio problem
Old Apr 25, 2006 | 09:19 PM
dave13's Avatar
Default 03 excursion radio problem
i just pulled my radio out of my 03 excursion and when i put it back in all the features worked except for the 6 disc CD . i get a CD error when i try to access the CD feature. i can not eject the CDs either. is there a reset or somthing that needs to be done or something? thanks
Old Apr 27, 2006 | 12:46 AM
RandysFT's Avatar
Default RE: 03 excursion radio problem
Did you plug everything back in correctly? Sounds like something is disconnected. Try disconnecting the ground wire on the battery for a couple minutes to reset everything.
Old Sep 8, 2006 | 03:01 AM
kru's Avatar
kru
You may have bumped something a little too hard. Those units are extremely sensitive. Most of them have a sticker on the top of them that says "Scrap if dropped"
Old Mar 15, 2007 | 01:32 AM
boostbusa's Avatar
your cd mechanism is jammed and these are not cheap to repair I work for a audio shop here in florida and those at my cost are about $395.00 to refub entire unit at a flat rate fee.good luck,Tim
Old Jul 7, 2007 | 03:37 PM
krazypaws's Avatar
I have that problem now with my fav cds in there does any one know how to get the cds out so I can scrap this piece of junk.
tatman
Jul 23, 2009 05:45 AM
b3n129
Sep 20, 2008 05:59 AM
larmak90
Oct 22, 2007 09:46 AM
larmak90
wwjd216
Jun 7, 2005 06:43 PM
