Coolant Temp: Actual -vs- Thermostat
Old Apr 30, 2006 | 11:23 AM
lakeroadster's Avatar
Default Coolant Temp: Actual -vs- Thermostat
I have a '83 5.0 HO motor in my Model T Roadster. The motor is basically stock, using the stock aluminum intake but with a Holley 600, Headers and a slight bump in compression. My question is what temperature does your water temp. gauge read? I am running the stock 195 degree thermostat and my Stewart Warner gauge reads right around 200 degrees. While I realize there will be a temperature gradient since the temp. sensor isn't located right at the thermostat I was merely wondering what other peoples actual temp. gauge readings were.
l2rocku2
Jan 5, 2009 11:30 PM
americanmade929
Jul 27, 2008 01:15 PM
GBINKSTER
Jun 8, 2006 09:49 PM
