a/c & interior fan do not operate! help
Old May 20, 2006 | 11:59 PM
storm352's Avatar
Default a/c & interior fan do not operate! help
2000 ff,a/c will not operate nor will interior fan, a/c no indicator light, interior fan does not operate, checked fuses below dash, check fuses under hood, all fuses seem fine, what suggestions ?
Old May 23, 2006 | 09:27 PM
hockeyhitman69's Avatar
Default RE: a/c & interior fan do not operate! help
does the blower motor work?
Old Oct 25, 2006 | 01:16 AM
SFPD770's Avatar
Thank Glennzo for this, it worked for me.......
It IS the blower resistor. The same thing happened on my 2002 focus. The resistor is behind the glove box. Less than $20 from Ford dealer and 20 minutes to replace. Drop the glove box all the way down. Use a 1/4 drive 8mm with a long extension to remove the 1 screw holding the resistor in. Unplug resistor, plug new one in and replace screw. Done.
rmanick1
Aug 5, 2014 09:15 AM
mrdgzpm
Mar 3, 2013 12:27 AM
jghardt
May 27, 2012 01:21 AM
caper74
Apr 25, 2008 01:11 AM
dan007nj
Apr 11, 2008 12:02 AM
