93 tbird no crank no start, batterygood
Old May 29, 2006 | 08:52 PM
ivgotit's Avatar
Default 93 tbird no crank no start, batterygood
Problem: when I turn the ignition key to start car, the starter relay solenoid clicks but nothing else happens. All lights, radio work fine.
What I have done: checked battery and connections (good), tried another new battery, checked ground (good), checked neutral safety switch (good), replaced relay solenoid, replaced starter, hotwired starter (good), replaced power cable to starter. Same problem persists.
Does anyone have any other pointers for me? I am stumped. Thanks.
Old Jun 2, 2006 | 12:16 AM
Duffs302's Avatar
Default RE: 93 tbird no crank no start, batterygood
Have you tryed manualy turning the eng. from the crank? It sounds like the eng. is lock up.
Old Dec 4, 2006 | 12:06 AM
rustbucket89's Avatar
my bronco did the same thing. i bought a ground cable with a terminal on it already and i grounded it to the alternator bracket, and miraculously it started. i would try this.
chris015
Aug 4, 2012 09:35 AM
adam
Jul 29, 2010 02:04 AM
kyyooper
Jan 3, 2008 10:11 PM
kraussy783
Mar 25, 2007 02:37 AM
