1998 Ford Crown Victoria 4.6L TRACTION CONTROL PROBLEM??
Old Jun 1, 2006 | 09:12 PM
s007059's Avatar
Default 1998 Ford Crown Victoria 4.6L TRACTION CONTROL PROBLEM??
I have a problem with my 1998 Ford Crown Victoria 4.6L as I drive it if I accelerate fast it will not let me go over 50 mph and the traction control light starts to flash. It is as almost as if the the accelertor pettle is cut off. If I pull over and bring it under 30 mph and bring the acceleration up slowly it will work ok. If I turn of the traction control by pressing the trac off button in the glove compartment the car will run perfectly fine. I was told that in this year these cars have problems with the ABS modules and ECM. I replaced the ABS module and had my ECM flashed. The problem is still persisting. I have tested the traction control switch and it is working fine. The Brakes and rotors are new. There are no codes present. Anyone have any Ideas??????I need help.
Old Nov 11, 2007 | 11:44 AM
assami's Avatar
Default RE: 1998 Ford Crown Victoria 4.6L TRACTION CONTROL PROBLEM??
so . any news on this.
i have the same thing !!
did you fix it ?
Old Nov 24, 2011 | 07:16 AM
rich288oh's Avatar
this is just a shot in the dark, but have you checked your abs sensors located at each wheel. if these are coroded or covered with foreign debris it can cause problems.also check the continuity between the sensors and the module.
lcarlton1102
Sep 20, 2013 04:04 PM
crown vic jc
Jul 5, 2008 04:09 PM
s007059
Jun 1, 2006 11:16 PM
s007059
Jun 1, 2006 09:16 PM
s007059
Jun 1, 2006 09:12 PM
