97 Aerostar 3.0L V6 Crank Won't Turn
Old Jun 7, 2006 | 07:57 PM
collinsjamest's Avatar
Default 97 Aerostar 3.0L V6 Crank Won't Turn
This weekend I was driving in the mountains, and my 97 aerostar 3.0L V6 engine died while pulling up a hill. I originally thought it was the alternator because it wouldn't turn over. After testing the alternator, battery, starter and solenoid, I decided to try to turn the crank manually. It will not budge. I have broken two wrenches on it so far. I'm thinking that maybe the timing chain broke and is binding the crank shaft, but I haven't pulled the cover yet to check. Has this ever happened before? Is there a collision problem between the valves and pistons when the timing chain breaks on the 3.0L V6 engine? I am very surprised that this happened. I only have 109,000 miles on the van, and I was told that I could expect 200K plus before any hardcore engine issues. Someone please help!
Old Apr 12, 2007 | 11:42 PM
stonewall's Avatar
Default RE: 97 Aerostar 3.0L V6 Crank Won't Turn
it seems like seized pistons to me. caused by no oil in the crank case. wish you luck......
Godzilla
Feb 2, 2008 09:58 AM
nightmach
Dec 24, 2007 05:10 PM
Dan71
Sep 6, 2005 12:11 PM
Dan71
