MY '98 EXPLORER HAS SERIOUS ISSUES
Old Jan 17, 2005 | 01:16 AM
tboy83's Avatar
Default MY '98 EXPLORER HAS SERIOUS ISSUES
MY FRONT END MAKES A CLICKING SOUND AND VIBRATES. I THINK IT MIGHT BE MY DIFF. THEN MY DRIVER DOOR LOCK BUT DOESN'T UNLOCK. I THINK THAT MIGHT BE THE LOCKING SOLENOID. ANYONE WITH ANY ADVICE WOULD BE OF GREAT HELP.
Old Jan 19, 2005 | 07:03 PM
josser's Avatar
Default RE: MY '98 EXPLORER HAS SERIOUS ISSUES
If you only hear the clicking sound when you turn, it is could possible that you need new wheel bearings or ball joints. But first try and pack the seals and joints with grease and see if the clicking goes away. Also usually when you make a hard right or left the outside front wheel will hop, that is normal on 4WD.
Old Jan 24, 2005 | 07:18 PM
And as for the door, its sound like the door switch is the problem. If it locks then the wires to the soleniod are good. It unlocks be reveasing the polarity to the solenoid. If the other door locks and unlocks you might be able to test your door with its switch.
Old Mar 22, 2005 | 05:16 AM
dadstaxi's Avatar
clicking=bad cv axle shaft my wife has 98 eplorer sport allwheel drive,door lock=bad lock accuator
Old Mar 22, 2005 | 01:24 PM
Agree with the axle shaft and joints, disagree with the accuator, if it works one way it should the other, its the switch.
wyteblazed
Apr 7, 2014 11:28 AM
Joe Feds
Aug 19, 2009 07:33 AM
armygrunt2u
Jun 3, 2006 11:04 PM
cddrake
Dec 3, 2005 04:30 PM
tboy83
May 16, 2005 03:50 PM
