A/C blower motor only working high speed
Old Jun 9, 2006 | 03:11 PM
SFPD770's Avatar
Default A/C blower motor only working high speed
I have a 2002 Focus ZX5. A few days ago I turned on the a/c and after I turned it up to high, something went wrong with it and now high is the only fan setting that works. Cold air can be felt coming out of the vent in speeds 1-3 (even though the blower isn't working), and when the fan setting is on 4 the light on the a/c button goes off, and the fan blows out the cold air that is in there and then goes back to blowing vent air through the cabin. Is there a resistor or inline fuse that has been blown? And is it an easy fix or should I take it to the dealership?
Old Jun 9, 2006 | 03:20 PM
Mulletman's Avatar
Default RE: A/C blower motor only working high speed
Sounds like the blower resistor went out on you. I would start there.
Old Jun 10, 2006 | 02:19 AM
SFPD770's Avatar
Thanks Mulletman!!
Is the blower resistor located near the blower or in line?
Old Jul 29, 2006 | 11:58 PM
glennzo's Avatar
It IS the blower resistor. The same thing happened on my 2002 focus. The resistor is behind the glove box. Less than $20 from Ford dealer and 20 minutes to replace. Drop the glove box all the way down. Use a 1/4 drive 8mm with a long extension to remove the 1 screw holding the resistor in. Unplug resistor, plug new one in and replace screw. Done.
Old Jul 30, 2006 | 12:57 AM
Mulletman's Avatar
^ yup! glennzo nailed it for you!
Old Oct 24, 2006 | 06:28 PM
SFPD770's Avatar
Thanks Guys! U nailed it!
makuloco2000
Jun 6, 2014 12:25 PM
ejanik
Apr 10, 2013 09:24 PM
tomdsr
Sep 28, 2010 03:29 AM
Brooklyn Bob
Jan 3, 2009 10:29 AM
bcmsteve
Jul 23, 2008 02:09 PM
