2.5L Probe GT Backfires with accelleration
Old Jun 12, 2006 | 08:01 PM
estecondios's Avatar
Default 2.5L Probe GT Backfires with accelleration
My 1995 Probe GT 2.5L (v6) lugs, chugs, and backfires under stress. Stress including moderatele accelleration up hills or hardER accelleration on flat ground. I've changed the fuel filter and added a cold-air intake but it has not fixed the problem. I've also replaced the plugs but not the wires since I was on a budget and it lessened but did not fix the chugging. Incidentally, once in a while if I'm going down hill and I let off the gas and shift into nuetral the car will rev down and then die. I can start it up again with no problems, however.
Also, it runs poorly (even more backfiring and the like) when the air is humid. This clearly points toward an ignition problem but I don't want to fix something for no reason.
Now, I've heard that it could be my plug wires, fuel pump, or knock sensor causing the problem but replacing these to test the theory is money that I don't want to blow. I'm having the computer read tomorrow but I was hoping that someone here would have an opinion as to a fix.
Thanks for the help.
Old May 12, 2008 | 11:45 PM
Default RE: 2.5L Probe GT Backfires with accelleration
Bofore I ever replace spark plugs OR wires I replace the distributor cap and rotor (unless it's distributorless then check coils spark output efficiency).
oldad
Apr 17, 2013 06:00 PM
rojaspga
Dec 2, 2011 01:46 PM
longbowdog
May 9, 2009 03:20 PM
estecondios
Jun 16, 2006 07:05 PM
estecondios
Jun 14, 2006 01:49 AM
