*NEW* optima battery for sale $82.00
Old Jan 19, 2005 | 11:34 PM
Battery_guy's Avatar
Default *NEW* optima battery for sale $82.00
Optima Red Top - 75/35 - Cars Trucks, SUV Battery
*NEW*
Cranking Amps- 910 Cold Cranking Amps- 720 Reserve- 90 Dimensions are 9.4"x 6.8"x 7.6" Weight is approx. 33.1 lbs. Battery has Top Post and Side Terminals with handle for easy installation Warranty.....36 Months Free Replacement and 72 Months pro-rated In any vehicle or equipment that will use the battery only for Starting, Lighting, & Ignition requirements and has a properly working alternator, the OPTIMA Red Top™ Starting Battery will perform extremely well, often providing up to two times longer life than conventional batteries. If the vehicle has few or no after-market accessories and uses a stock or upgraded alternator, the OPTIMA Red Top Starting Battery is the appropriate choice. Remember, it is possible for the customer to have a completely discharged Red Top OPTIMA that will not start their engine; the advantages of the Red Top are that it can accept a rapid recharge and it will recover from discharge many more times. To provide the customer the best OPTIMA solution, it is, necessary to consider both the application and the charging system before recommending the correct OPTIMA. For example, if your customer has a Ford Expedition with an after-market alarm system, which OPTIMA would you recommend? If the customer drives the car every day, the Red Top would be the correct choice, since the amperage drain will be nominal and the battery would be recharged on a daily basis. However, if the customer stores the vehicle for a long period of time with the alarm system engaged, you should recommend the OPTIMA Yellow Top, since the amperage drain over several weeks would damage a Red Top and reduce its life.
Battery is $82.00 and shipping is $15.00 anywhere in the USA
I offer all Optima Batteries at low prices so if you have questions or want pricing please email me at battery_guy@hotmail.com
Old Aug 14, 2010 | 12:42 PM
likeit03's Avatar
*NEW*
I need one do you have any more?.Thanks
Captain B
11
Apr 26, 2023 01:07 PM
guthrie1013@gmail.com
Jun 25, 2020 11:45 AM
irinadel
Jul 30, 2011 09:46 AM
mcleaves
Aug 19, 2008 12:44 PM
Winstargirl
Feb 14, 2008 03:05 AM
