1997 T-bird. Clinking sound when shifting from park to reverse
Old Jul 18, 2006 | 08:12 PM
cindymac's Avatar
Default 1997 T-bird. Clinking sound when shifting from park to reverse
I just had my transmission fluid and filter changed and now my car makes a clinking sound when I shift from park to reverse or visa versa. The mechanic doesn't seem to know what it could be. Does anyone have any idea? It didn't do that before he changed the fluid. I would appreciate any help. Thanks
Old Aug 1, 2006 | 12:21 PM
Duffs302's Avatar
Default RE: 1997 T-bird. Clinking sound when shifting from park to reverse
I had a 93 ranger that did that, I was told that it was play in the rear end that cause it. Also it could be a loose drive shaft.
Old Aug 1, 2006 | 08:08 PM
94 4x4 ranger's Avatar
You can always bring it to a transmission shop for a free estimate. Problems like this are hard to diagnose over the internet.
Old Aug 4, 2006 | 04:34 PM
Mulletman's Avatar
I would inspect the U-joints on the driveshaft.
Old Aug 7, 2006 | 02:44 AM
sisdavid@yahoo.com's Avatar
Seems like if it just happened after changing fluid. could be something up with that. Is true that over internet hard to figure out. Ya, know what kind of clunking noise. To difficult to try to tell someone what the noise sounds like or what ever. How long have you used the mechanic that changed the fluid?
Old Sep 18, 2006 | 11:34 PM
FORDever's Avatar
sounds like the u-joint is going bad now.
Old Mar 24, 2007 | 10:47 PM
iplaypearldrums's Avatar
My t bird occaissionally does that ('95T) clink sound ,I also had a e150 ,1976, that did that. Sounds like u joints.....be conservative on the gas, getting to a u joint on a TB is a royal pain due to limited access...+$300 job here in Tampa.
spatterfree
May 11, 2014 08:58 PM
maxpower
Jun 24, 2013 08:58 PM
TIMF150
Aug 31, 2012 11:51 AM
goiou
May 16, 2009 10:40 AM
josser
May 13, 2005 01:04 AM
