Check Engine Code p1409
Old Jul 24, 2006 | 12:11 AM
Airborne4X4's Avatar
Default Check Engine Code p1409
2002 Escape flashing the engine code p1409 (egr vacuum regulator solenoid curcuit). What should I check first?
Thanks,
J
Old Jul 24, 2006 | 01:18 AM
Mulletman's Avatar
Default RE: Check Engine Code p1409
P1409 EGR Vacuum Regulator Solenoid Circuit Malfunction Detailed Description
This test checks the electrical function of the EGRVR solenoid. The test fails when the EGRVR circuit voltage is either too high or too low when compared to the expected voltage range. The EGR system must be enabled for the test to be completed.
Possible causes :-
EGRVR circuit open.
VPWR open to EGRVR solenoid.
EGRVR circuit short to VPWR or GND.
Damaged EGRVR solenoid.
Damaged PCM.
Diagnostic Aids
The EGR vacuum regulator solenoid resistance is from 26 to 40 ohms.
REPLACE EGR vacuum regulator solenoid.
a_frenchswallow
Sep 27, 2010 07:53 AM
spedaleden
Feb 21, 2008 08:24 AM
robinlyn
Jun 17, 2007 10:19 AM
stacy98exp
Oct 11, 2006 01:37 PM
dmcarthur
Jun 29, 2005 04:43 PM
