1967 Ford Mustang Wiring
Old Jul 24, 2006 | 01:36 PM
Darr67's Avatar
Default 1967 Ford Mustang Wiring
Not cool
Last edited by Darr67; Feb 7, 2012 at 09:43 PM. Reason: this was posted on the internet!!! Not Cool
Old Jul 29, 2006 | 02:18 AM
floyd's Avatar
Default RE: 1967 Ford Mustang Wiring
one cable goes from the stud on the side of the starter to the solenoid. the other cable is the ground from the bolt that mounts the starter at the engine/belhousing it goes to the negative post on the battery. the positive post of the battery is then attached, with a third cable, to the other large terminal of the solenoid. the small terminal is for the ignition wire. the fusible links should be attached to the battery side of the solenoid. good luck
vrwilson
Apr 7, 2010 03:21 AM
pinupgirl874
Apr 7, 2008 03:44 PM
Fraley
Apr 3, 2008 04:24 PM
pinupgirl874
Apr 3, 2008 04:20 PM
rebelman108
Jun 27, 2006 12:11 AM
